Got my Chip, Programmer & Software
Discussion in 'Programmer's Corner' started by Chris15, Dec 16, 2010.
  1. Chris15
    Thread Starter Active Member
    Apr 15, 2009
    252
    Hello
    I had a previous thread on Programming, i have this:
    - A hex file ready to put on my chip
    - The Chip, an ATtiny13A
    - AVR ISP MKII Programmer
    - AVR Studio 4
    What do i do to get the hex file on the chip? will this work?
    http://www.youtube.com/watch?v=AJZO0q3Gzbw&feature=related
    I can just connect the Tiny13 to the AVRISP MKII on a breadboard, go into AVR Studio 4, press AVR Prog, put in the HEX and press program, then its all done?
    Chris
  2. maxpower097
    Feb 20, 2009
    795
    388
  3. Chris15
    Apr 15, 2009
    252
    Yes so..
    When connecting the Pins from the 6plug socket out of the AVR ISP to the Chip, is the red line on the rippon mean that when thats ontop the top left pin is pin one, or can i connect it like this photo
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    The uC needs to be mounted to a circuit board with the ICSP programming header on it. The IC doesn't plug directly into the cable you have in the photo.
  5. Chris15
    Apr 15, 2009
    252
    Yes i am going to put the Chip on a breadboard and attatch jumpers from the breadboard into the header Plug from the ISP MKII
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    The red conductor associates with pin 1 on the connector.
    The Youtube link you provided is for the dragon. You are not using a dragon, you are using the AVRISP MKII.
    You need to make sure that your ATTINY13 breadboard has the ISP6PIN header wired into it.
    Your AVRISP MKII will plug into the 2 by 3 header on your prototype board.
    hgmjr
  7. Chris15
    Apr 15, 2009
    252
    Ok yes so i need to find how to attatch the ISP MKII to the ATtiny13 like a picture or something
    Once it is connected, i verify it in AVR Studio 4 with that Chip looking button that says 'AVR'
  8. hgmjr
    Jan 28, 2005
    9,030
    214
    You have successfully loaded AVRSTUDIO4 on your PC, right? And it runs, right?
    hgmjr
  9. Chris15
    Apr 15, 2009
    252
    Also their is a Fuse Setting thing you talked about hgmjr what is that? is it important, can i just download the HEX file to the ATtiny13 using the AVR Studio 4 Programming tool and not have to change the fuse, with the youtube link, i know its the dragon, but is what is explined in the video the same for me?, i open the AVR Button and press prgram once i load the HEX file?
  10. Chris15
    Apr 15, 2009
    252
    Well i have it ready to be plugged into my computer noe but i dont know wat to to then? once i plug it in i open AVR Studio 4 and do the configure thing on AVR button
  11. Chris15
    Apr 15, 2009
    252
    Yes AVR Studio 4 runs
  12. Chris15
    Apr 15, 2009
    252
    sorry, Yes AVR Studio 4 Works Fine yes, i have everything ready to go here but i lack the knowlege of what to do
  13. hgmjr
    Jan 28, 2005
    9,030
    214
  14. Chris15
    Apr 15, 2009
    252
    I just run an Update for the AVRISP MKII in AVR Studio 4 and it says its all good, so now everything is working i jus have to connect the chip to the AVRISP MKII On a breadboard, load HEX and press program
    Chris
  15. Chris15
    Apr 15, 2009
    252
    Thanks for the Picture on connection to the ATtiny13 :)
  16. Chris15
    Apr 15, 2009
    252
    i dont fully understand that picture? the six pin connecter is where , what connects? i have a picture i think you uploaded here
  17. Chris15
    Apr 15, 2009
    252
    In this picture i jus connect everything from the 6pin Header to the Chip and not worry about anything else?
  18. Chris15
    Apr 15, 2009
    252
  19. hgmjr
    Jan 28, 2005
    9,030
    214
    Yes the schematic and the table look good. The schematic shows the ISP6PIN header from the top.
    hgmjr
  20. Chris15
    Apr 15, 2009
    252
    Ok thanks, How do i find Pin 1? is the red line indicating that if the 6 holes are facing me and the red line is ontop the top left is pin 1?
    ---- +1 +2
    +3 +4
    +5 +6
