Got motor from scrap yard looks like from washing machine, need help finding wiring diagram
Discussion in 'General Electronics Chat' started by wilsonintexas, Jun 9, 2015.
  1. wilsonintexas
    Jun 9, 2015
    I was at the scrap yard and picked up a motor laying in the pile. It has 205850 on the sticker for a type number as well as speed 16000 110 volt.
    It has 2 wires going to a tach
    it has 3 wires going to the motor (red, grey, black) I measured 2.8 ohms between each of the leads (so a delta configuration??)
    I want to use the motor, and can not find a wiring diagram.
    It looks like it is close to this motor Whirlpool 8182793 (which is 17500 rpm) But these are used in front loader washing machines with belt drive.
    It appears to be brushless
    I do not see a centrifugal switch
    I would also like to take off the tach and use it in a separate project, so I would like to find some specs on it. I would like to be able to digital readout eventually that would be he RPM.
    I appreciate any help.
    so, I would appreciate a link to any wiring diagrams that would help me to figure out how to wire the motor.
    I would appreciate any tips on how to reuse the tach in different motor (and would like any diagrams that would help me with that)
    Thanks for the help.
    I did search but could not find anything on this motor.
    I found many on older motors, but nothing that came close to the 3 wires that I see on this motor.
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    I believe you have one of the small 3phase motors fitted to front loaders.
    If so you need a VFD of some kind to run it.
    If you short the three wires and try and spin the shaft, if it resists movement it is a P.M. motor, if not difference it is induction motor.
    Max.
  3. wilsonintexas
    Jun 9, 2015
    The budget it tight on this project (which is why I was at the scrap yard looking for parts).
    I will go through the craigs list locally and check for people givingaway free washing machines, and check the model numbers. It may takea while, but I will eventually find one that I can take the control module out of.
    It is never easy.
    On the tach, I guess I can spin it up and see what the volts per rev are, and hope it is some nice number.
  4. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    A internet source turned up it is a 3ph induction motor, the tach is either 3 output for commutation, or if single, usually a low res mag sensor <50p/rev.
    Max.
  5. wilsonintexas
    Jun 9, 2015
    new to this forum sorry.
    Theodore_a_wilson@yahoo.com
  6. wilsonintexas
    Jun 9, 2015
    Thanks for the info. I will look a t a vfd or keep an eye out for a broken newer front loader and see if I can get some parts. If it were 220 three phase, I have several other 3 phase motors I cold generate the third leg, not sure how to do it with 110 three phase.... I guess seveal big caps.... I will look for vdf schematics. I did find the motor controller as a spare part, but it would break the budget.
    if nothing else, I will scrap the copper and reuse the bearings and balanced shaft.
