First, a little rant: This meter was $99 + $35 shipping, which was a pretty good deal. That made it around £85. But because I ordered it from the USA (couldn't find it *anywhere* in the UK) I had to pay £23 in customs fees / VAT. That made it a bit more expensive than I had originally intended.
But, it is a nice meter. It's a BK Precision 2709B. True RMS, 6,600 counts, 0.5% basic DC accuracy. Very good protection; two massive MOVs according to internal pictures, along with HRC fuses. Continuity mode is fast (<100ms) and latched (which is very good.) Most other ranges autorange very quickly. Capacitance is a bit slow, but does go up to 66mF, and it does let you range switch through it. It measures frequency, up to 66 MHz(!), which eliminates my need to buy a separate frequency counter, for now at least, as long as I don't need to measure very high frequencies.
It's also got input jack detection. If you select a voltage range, but plug the probes into the current jacks, it beeps at you to alert you to this (very useful!) All ranges but AC/DC volts are protected to 500V; AC/DC goes to 750Vrms/1000V.
I chose it mainly because Dave Jones (eevblog) highly recommended it.
