I am facing some problem on Clutch & Break. It is used on Cutting machine when cutting command received both Clutch & break operate together hence break released & clutch engage & cutting process completes. Both coil voltage are 24 VDC. 66 watt & 65 Watt respectively. Both the coils are connected in series & 48 Volt DC is applied from controller. Now problem is when ever cutting command comes Break energies slightly late than clutch coil hence there is excess load on clutch coil. How we can operate Break coil quicker than clutch coil??
