Good transistor to control IR Emitters
Discussion in 'The Projects Forum' started by x1222, May 23, 2012.
  1. x1222
    Oct 22, 2011
    31
    I have 6 IR Emitters I want to use in a line follower sensor array. They each draw around 20 mA. Does anyone know a good model of transistor to use to control which IR emitters to turn on and off using my digital pins of my microcontroller?
  2. #12
    Nov 30, 2010
    16,685
    7,324
    2N3904, 2N3906, 2N2222
    cheap, common, general purpose transistors will do this job.
    x1222 likes this.
  3. MrChips
    Oct 2, 2009
    12,634
    3,453
    2N3906 is a PNP transistor. You probably don't want to choose that.
    x1222 likes this.
  4. #12
    Nov 30, 2010
    16,685
    7,324
    Probably true. I thought the answer was incomplete if I didn't include a pnp option.
