Good source for old transistors
Discussion in 'Wireless & RF Design' started by spinnaker, Oct 29, 2009.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,065
    1,163
    I dragged out my old Kelvin Electronics Solid State AC Operated Superheterodyne Receiver Kit Stock No. 137-19 that I built in high school about a century or two ago. :)
    Believe it or not, I still have the original builders guide and schematic.
    I'd like to get it working again.
    For starters I can see it is missing one 2n410 transistor. I have not gone through it yet but I would bet there are other bad transistors in the set too.
    So the complete list of transistors is:
    2N412
    2N410
    2N408
    2N3638
    Can anyone tell me a good source to purchase these parts or their replacements at a reasonable price?
    What would their replacements be?
    I really have not touched electronics for years. I hope I can recall some of my basic troubleshooting skills. :)
    For example: A simple ohm meter check should be reasonably good enough to check the transistors. Correct?
  2. darenw5
    Feb 2, 2008
    45
  3. KL7AJ
    Nov 4, 2008
    2,043
    292
    Probably the best source is Joel Ballek's garage. Let me look. :D
  4. spinnaker
    Oct 29, 2009
    5,065
    1,163
    Yikes and I thought I was a pack rat! :)
    Well to tell you the truth, I think I still have some old vacuum tubes around here. :)
  5. spinnaker
    Oct 29, 2009
    5,065
    1,163
  6. KL7AJ
    Nov 4, 2008
    2,043
    292
    I have HUNDREDS of vacuum tubes. Three tube testers.....and a partridge in a pear tree!
  7. KL7AJ
    Nov 4, 2008
    2,043
    292
    Those are all germanium transistors.
    Eric
  8. studiot
    Nov 9, 2007
    5,005
    515
    Welcome back to electronics.
    It would make a good addition to the project to find out a bit about these transistors (and transistors in general) while you are about it.
    The 2N4xx transistors are very low voltage, low current germanium jobs (PNP). However they are relatively high frequency What was the range of your superhet? Did you have a 4.5, 6 or 9 volt battery?
    The 2N3638 is a bog standard silicon pnp low power transistor, probably used for a simple output to headphones or high impedance speaker.
  9. spinnaker
    Oct 29, 2009
    5,065
    1,163
    It's an AM radio. Powered by a DC power supply 18.6 V.
    I checked all of the transistors. The RF stage transistor and first stage IF seems fine. The second stage IF is missing (2N410). Looks like both audio amp transistors (2N3638) are completely shorted.
    I am including a schematic.
    Since the audio transistors are shorted, do I need to worry about any of the other components?
  10. ELECTRONERD
    May 26, 2009
    1,146
    16
    If you don't find any subtitute transistors, and it could be for just a couple, you will have to bias the transistors a little differently with the resistors. This will ensure nearly the same performance just like the old transistors performed; except you have different transistors and different component values.
    Austin
  11. studiot
    Nov 9, 2007
    5,005
    515
    Have you tested the audio transistors out of circuit? With all those tramsformers they might appear shorted to an ordinary ohmeter.
    Incidentally older ohmeters have an output battery of 22.5 volts on the high ohms range. This would kill those germanium transistors, with a rating of 13 volts. The silicon ones are rated at 25 volts.
    I don't understand. The germanium transistors would be the most expensive and hardest to replace or substitute. Any general purpose silicon pnp one will substitute for the 2N3638
  12. spinnaker
    Oct 29, 2009
    5,065
    1,163
    Yes I pulled them out of circuit. All the transistors are in sockets so it is easy to do.
    I have a newer digital multimeter. A cheap Radio Shack model. I tested with that. At first I tested with the K Ohm range. I hope I did not blow them. Then I realized it has a diode checker so I used that mode for the remaining ones.
    Should I test them again?
  13. k7elp60
    Nov 4, 2008
    478
    69
    NTE semiconductor lists replacements for them at there website:
    http://nte01.nteinc.com/nte/NTExRefSemiProd.nsf/$$Search
    A source for them could be mouser electronics, www.mouser.com
  14. ELECTRONERD
    May 26, 2009
    1,146
    16
    Transistors are different from diodes. You might not have it on a cheaper multimer, but a adequate test would be a transistor tester. They should have these little holes four pins on each side. Take a look at the attachment, you'll find the transistor tester circled in red. This actually measures the gain of the transistor.
  15. spinnaker
    Oct 29, 2009
    5,065
    1,163
    I don't have a transistor tester on mine. I was just worried blowing the germaniums. Could I have blown them with this meter?
    I was able to test the audio amp transistors. Those are obvious, they are completely shorted.
  16. spinnaker
    Oct 29, 2009
    5,065
    1,163
    NTE does not come up with a price. Do you need to call them?
    I also fond some here
    http://stores.sacelec.com/sacramentoelectronics/detail.jsp?y=0&x=0&find=2n410&-skipRows=0
    and here
    http://www.galco.com/scripts/cgiip.exe/wa/wcat/itemdtl.r?listtype=&pnum=2N410-RCA
    The packaging on the second one looks nothing like the ones I have (mine look more like the first). Does that matter?
  17. ELECTRONERD
    May 26, 2009
    1,146
    16
    No, you certainly wouldn't blow them, and they shouldn't make any strain on the transistors. Meters use low value sources (current, voltage, and resistance) to take measurements so that they don't have much effect on the part under test. Your method just won't have much effect for accurate measurements. Put the transistors back in the radio and check to make sure if they have the voltage drop (around 0.3-0.4V for a gernamium). If they don't, then they are bad transistors. Also, you can calculate what voltages the transistors are operating at and then measure what the true voltage really is at those points. So simply start from the main voltage source and work your way down to what voltage the transistors should have, then see if they are under the correct conditions.
    Austin
  18. caleyates
    Dec 10, 2013
    Would you like to sell your Kelvin Superheterodyne Receiver Kit, including the Builder's Guide and Schematic? If not, would you be willing to copy the Builder's Guide and Schematic for me and send it to me for a fee?
    Thank you VERY much for considering my offer.
  19. Ramussons
    May 3, 2013
    562
    92
    I'd say TR1, TR2, TR3 = AF114 / AF116
    TR4 = AC 126
    TR 5, TR 6 = AC128 / AC188
    Ramesh
  20. studiot
    Nov 9, 2007
    5,005
    515
    Please note how many years old the original post is.
