Hi, I'm trying to build this TENS circuit here:
http://chemelec.com/Projects/Tens/Tens-3.png
It calls for a 2SD401A PNP transistor.
Can I just replace it with a generic, high voltage NPN transistor? I believe the TENS circuit simply switches high voltage (80-100v) at around 300hz. I think the speed is fine for modern transistors, so all I need to do is find one that can handle the voltage?
