Good Practice in soldering and pin connections
Discussion in 'General Electronics Chat' started by Šamaš-šum-ûkīn, Oct 16, 2014.
  1. Šamaš-šum-ûkīn
    Oct 10, 2014
    13
    this is more about a confirmation than anything else (or correction if wrong).
    When we have a peripheral connector with unused pins, the good practice is to connect the unused pins to a GND, right? To avoid logical level flicking because of the surrounding noises...? How critical are the those flickers to pins that aren't even used?
    Just curious.
    Regards,
  2. MrChips
    Oct 2, 2009
    12,636
    3,454
    Connect unused inputs only, not unused outputs.
    Whether you connect to Vcc or GND depends on the function of the input pin.
  3. ISB123
    May 21, 2014
    1,240
    531
    Solder a pull-up/down resistor.
  4. Šamaš-šum-ûkīn
    Oct 10, 2014
    13
    My favorite question: Why? Why stabilizing the logical level of inputs only? What happens if we don't do that? I know this might be a very basic question, but I've just entered into the world of electronics. :)
  5. ISB123
    May 21, 2014
    1,240
    531
    The pin will act as an antenna and it can introduce EMI in your signals.
  6. mcgyvr
    Oct 15, 2009
    4,791
    976
    The answer is maybe or depends on the specific details/functions/requirements of that product..
    I'll tell you that I don't ever have any unused pins on "peripheral connectors" (chips/ICs yes and I follow the recommended practice in the datasheet)..
    The extra/unused pins in a connector simply cost money..
    If its unused.. why even have it in the first place.
  7. MrChips
    Oct 2, 2009
    12,636
    3,454
    Are you referring to input pins on an IC or pins on a connector that are N/C (not connected)?
  8. Šamaš-šum-ûkīn
    Oct 10, 2014
    13
    Nice answer from both of you. I see the chosen design is already a bad practice given the partial use of peripheral connectors. Also, now I understand the idea of parasitic EMI; every signal affects the other. Flickering signals that are too close will affect the precision or proper working of other neighbouring signals.
    Case closed. ;)
  9. Šamaš-šum-ûkīn
    Oct 10, 2014
    13
    In fact, the peripheral connectors (if the name was correctly used) I am referring to are like this: [​IMG]
    From one PCB board to another with a multi-wire bus male connector.
  10. MrChips
    Oct 2, 2009
    12,636
    3,454
    It depends on what is connected to the pin.
    I would say leave the pin alone - don't connect anything unless you are told to connect to something.
  11. KeepItSimpleStupid
    Mar 4, 2014
    1,276
    224
    Usually you attach to whatever results with the lowest power dissipation.
