Good place to buy fuses?
Discussion in 'General Electronics Chat' started by trader007, Jan 18, 2013.
  1. trader007
    Thread Starter Active Member
    Feb 27, 2010
    222
    19
    Im wondering if there is a specialty site where you can buy different types of mico fuses- something that makes it easy to get something that not only has the same characteristics it must also look the same as oem.
    i know about digikey and mouser, but i often have manufacturer part numbers and it takes time to make sure whatever mouser or digikey has will be cross compatible.
    if those are the best site to buy from, does a cross compatible list exist?
    for example, in a betacam machine i have a blown 1.25a/125v fast acting fuse, according to sony. Part number 1532-777-21 and described as TMD fast acting.
    sony wants $16 for it, and i can get it elsewhere for $14... just think there has to be a better solution... thanks for the help in advance.
  2. mcgyvr
    Oct 15, 2009
    4,791
    976
    Digikey/Mouser/Newark
    BUT you WON'T find a master cross ref. from an OEM "internal part numbers" to actual manufacturer part numbers.. And as a manufacturer we DON'T want to make it easy.. We want you to buy the fuse from us at a marked up replacement price..
    There is no "Easy" button for the "cheap".. thank god
    Only took me a second to find this.. And would only take me a few seconds to find the part to purchase on Digikey or other sites..
    http://www.walterfuse.com/p_list.php?id=TMD&code=5
  3. trader007
    Feb 27, 2010
    222
    19
    pretty much what i figured. it gets even better when the high priced parts arent even available.
    thanks for your help though.
    edit- thats not the part, not even close. i have been searching on digikey, but its at the point where my lost time is more costly then just buying the oem part.
  4. paulktreg
    Distinguished Member
    Jun 2, 2008
    623
    124
    When you say micro fuse do you mean the circular cannister style fuse with two wires that plugs into a socket? I think fuses are overated, no pun intended, and you can get ripped of at times and $16.00 for a "fuse" is ridiculous!
    How about a picture of the fuse?
    You can buy a T1.25A fuse for pence!
