Good-day all. Please I Urgently Need 100 kHz Functin Generator Circuit
Discussion in 'The Projects Forum' started by nma, Feb 1, 2016.
  1. nma
    Feb 1, 2016
    15
    Good-day all. Please I urgently need help with my project. I am working on a signal generator that can generate three wave forms: Square wave, triangular wave and sinewave. The maximum frequency is 100kHz. I used op-amp (TL072). The square is on coming out well.
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    there are chips designed for that, look up MAX038, XR2206, and such.
  3. Dodgydave
    Jun 22, 2012
    5,130
    766
    Try making a Wien oscillator with your op amp,..
  4. atferrari
    Jan 6, 2004
    2,663
    783
    The help you require is going to cost you dearly because it will require previous adivination to know what circuit you did implement.
    Just in case, providing a schematic, the cost is much much lower. Please reconsider.
    Ah, if urgent, cost goes high again.
  5. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,676
    1,294
    I think what AT is trying to say is - no schematic, no answers.
    ak
  6. OBW0549
    Mar 2, 2015
    1,385
    929
    Without seeing a schematic diagram of your design, complete with all components and connections, we can't do much to help you.
    I can take one wild guess, however: if you're trying to use a section of a TL072 as a comparator to get your square wave output, be aware that at 100 kHz your square wave won't be very "square"; it will be more like a distorted, asymmetrical trapezoid because of the TL072's limited slew rate (typically 13 V/μS ). If you want a good, clean square wave use a proper comparator (LM339, LT1116, etc.) instead.
  7. nma
    Feb 1, 2016
    15
    Thank you very much for the response. I tried to use the MC and MAX038 but could not get it in my area. Any alternative I would not mind.
  8. nma
    Feb 1, 2016
    15
    Thanks for the response. I did not understand the response first but now clear. This is the circuit:
  9. nma
    Feb 1, 2016
    15
    Thanks for the explanation. I have sent the schematic.
  10. nma
    Feb 1, 2016
    15
    Thanks for the response. This is my schematic:
  11. nma
    Feb 1, 2016
    15
    Infact OB, I thought as much that TL072 could be the problem because of the slew rate. Please also check my other components because I am due to submit my work on wednesday.
  12. dl324
    Mar 30, 2015
    3,367
    642
    If this is a school project for which you will be graded, that's considered homework and should be posted in the Homework Help forum so responders won't simply give you answers.
  13. nma
    Feb 1, 2016
    15
    Please these are also the triangular wave and sine wave circuits below. Any corrections will be highly appreciated.
    triangular schematic from a simulation is
    sine wave from electronic workbench:
