Global variables initialization in C - required or standards-compliance?
Discussion in 'Programmer's Corner' started by dor, Jan 10, 2010.
  1. dor
    Thread Starter Active Member
    Feb 20, 2009
    62
    I read that in order to be compatible with the ANSI C standards, a C programmer must initialize all global variables before main() (which means: before program execution).
    But is this required for the program to work correctly?
    The code is hosted on a MCU EEPROM.
    Thank you :)
  2. sceadwian
    Jun 1, 2009
    499
    37
    Results will be unpredictable if anything in main itself or a function call from main needs the global variable before it's declared.
