Dickcappels afaik isopropanol isn't especially toxic to second cranial nerve but metabolites of *methanol* are! So don't use methanol or anything that contains it as denaturing agent cuz very small amount can do damage and once atrophy starts it can be progressive!... or damage your optic nerves, though that would be a lot to absorb through the skin.
Tnx @jpanhalt! You seem to have in depth knowledge of biology and health science (disciplines near and dear to me!)Since the subject of methanol has come up, it is sometimes mistakenly assumed that anything ending in an "ol" (i.e., an alcohol) is an active antimicrobial. Ethanol and 2-propanol (isopropyl alcohol) certainly are. Methanol has little if any practical activity. Butanol (C4) and longer alkyl-chain alcohols have decreased activity, as their water solubility is decreased. There are many studies on the relatively antimicrobial activity of ethanol and 2-propanol. This CDC report cites a few of them: https://www.cdc.gov/hicpac/Disinfection_Sterilization/6_0disinfection.html
My opinions of methanol:
1) Decent, sometimes unique solvent
2) Good model airplane fuel (and other fuel purposes)
3) Toxic on ingestion as in attempted suicides, but if treated early then effect on the eye can be abated. I am aware on one person who had a blood methanol concentration in excess of 300 mg% and survived with no visual defects. She was treated quickly. I would not be concerned about small incidental exposure to methanol vapor.
4) Many years ago, addition of methanol was the most common way to make ethanol non-drinkable ( "denatured") and there are cases of visual impairment related to individuals ignoring the label. There has been a strong push to avoid making denatured alcohol toxic for that reasons, and the focus has been on making it foul tasting or nauseating (see: https://en.wikipedia.org/wiki/Denatured_alcohol ); some brands still contain larges amounts of methanol, though. Klean Strip is one such brand (http://www.kleanstrip.com/uploads/documents/GSL26_SDS-1625.6.pdf ) for which the solvent properties of methanol apparently outweigh the health risk in the opinion of its manufacturer. You can check the MSDS for a particular product to find what is in it.
John
Yo Aleph! No problemo! IMO you are THE authority on all things alcohol!Here's disclaimer, I'm not health professional but I know what I'm talking about all the same
I find the first cause of athlete's foot is the usage of shoes with little or no ventilation. In the last two years I almost retired thus stopped using safety shoes and at home I stay barefoot or wear sandals even in winter. Not smelling athlete's anymore around here.Living in the tropics every couple of years I get a case of athlete's foot that defies the antifungal creams and pills. What has worked every time is a good long soak in a weak chlorine bleach solution. Simple, usually one treatment does it.
Jpanhalt Maybe you're right about no permanent harm from very low dosing but I can get scintillating scotoma (ophthalmic migraine) from just brief exposure to dilute vapors and I know of other ppl who have scarier reactions to just trace levels formed by hydrolysis of silanes!I would not be concerned about small incidental exposure to methanol vapor.
JC you know carboxylic acids have wide range of toxicity! For extreme example compare citric vs. oxalic!I confess to not understanding why formic acid acidosis is more harmful than acidosis caused by acetic acid
JC, in the words of _her excellency_ DARE TO THINK!or why the optic (2'nd cranial) nerve is specially vulnerable?
JC you know the exact opposite cuz you are trying to win points with HP by being humble studentI know HP will make me regret this
Careful, JC! Lest I loose *your* moldy skeletons!Yo Aleph! No problemo! IMO you are THE authority on all things alcohol!
I doubt itI know HP will make me regret this
--- Formatting and tabulation added ---I confess to not understanding why:
1) formic acid acidosis is more harmful than acidosis caused by acetic acid
2) why the optic (2'nd cranial) nerve is specially vulnerable?
HP that's TWO hints! HP now I say you are making same mistake as with RK cuz you are just giving him the answer with TMI hints!In response to question #2 -- I offer a single hint -- The 'enhanced' vulnerability of said nerve to formic acid and, to a markedly lesser extent, formaldehyde, owes far more to anatomy than to physiology... JC you know enough to answer the question for yourself! -- As per Aleph's daft deference to myself: 'Dare to think'! With special focus (NPI) upon the anatomy of myelinated nerves
HP I say all the breath holding practice you're getting will pay off on here too!I expect you to work this out prior to my return!
Maybe so -- For all that there is something to be said for maintenance of 'momentum'! -- For example, you (and others) felt that my introduction of 'Q' (Re: design of matching networks) was 'babying' RK ---- with the result that, in the absence of said 'perspective', he learned to design 'two reactor' networks but with the addition of an extraneous compensation reactor (relegating the lesson to a mere study/drill in complex arithmetic) --- Granting that RK may not have been a sincere student - I nonetheless assert that, is the student to remain engaged, 'interment' of concept by rote 'donkey work' is to be avoided at all costs - up to and including exposition!!!HP now I say you are making same mistake as with RK cuz you are just giving him the answer with TMI hints!
Yes, but let your feet dry completely before putting your shoes on. It also helps if the shoes are allowed to dry completely. If still moist from the previous day, wear a different pair.So could soaking your socks, in cheap vodka, also relieve athlete's foot?
--Emphasis added--So could soaking your socks, in cheap vodka, also relieve athlete's foot?
by Jake Hertz
by Jake Hertz
by Aaron Carman
by Aaron Carman
