hello i am having a problem with my touch panel in my easypic pro V7 with the PIC18F87K22 microcontroler as a default.
i need a help on how can i connect the touch panel to the board easypic? I have tried the default configuration that's come with the manual but is not working.
i followed those instruction:
Touch panel is enabled using SW4.5,
SW4.6, SW4.7 and SW4.8 switches.
They connect READ-X and READ-Y lines
of the touchpanel with RF5 and RF2
analog inputs, and DRIVEA and DRIVEB
with RE4 and RE5 digital outputs
on microcontroller sockets. Do not
connect additional boards or otherwise
interfere with these lines while you use
touchpanel, because you may corrupt the
results of the readings and get inaccurate
touch coordinates.
but is not working with the example code so i need your help on this....
touch coordinates.
