glass diodes
Discussion in 'General Electronics Chat' started by DexterMccoy, Mar 18, 2014.
Thread Status:
Not open for further replies.
  1. DexterMccoy
    Feb 19, 2014
    429
    what does glass diodes do different than black plastic package?
    Some glass diodes are germanium, why are they glass?
    what is the advantage of glass and what is the disadvantage?
  2. magnet18
    Dec 22, 2010
    1,232
    125
    it's just a different packaging choice, the pros and cons are mostly mechanical
    for example, in a vacuum system, glass diodes are preferred because they do not outgass like a plastic would
    on the other hand, glass is much more fragile
  3. DexterMccoy
    Feb 19, 2014
    429
    So glass last longer?
    How about cold and hot temps? does glass last better and longer?
  4. magnet18
    Dec 22, 2010
    1,232
    125
    I wouldn't say either lasts longer
    either could be designed to last centuries of constant operation
    there is no "better and longer" for all circumstances, it's a matter of how they are mechanically engineered for the expected environments (in the case of your question, temperature)
  5. DexterMccoy
    Feb 19, 2014
    429
    So glass packages are better with temperature?
  6. crutschow
    Mar 14, 2008
    13,505
    3,378
    Glass is also essentially perfectly hermetic whereas plastic is not, so glass is preferred in high humidity or wet environments. That's why plastic packages are seldom used in Military or other critical environments.
  7. KMoffett
    Dec 19, 2007
    2,584
    234
    Glass diodes are sensitive to ambient light. Black plastic diodes are not.
    Ken
    PackratKing likes this.
  8. DexterMccoy
    Feb 19, 2014
    429
    What do you mean by hermetic? the advantage is?
  9. KMoffett
    Dec 19, 2007
    2,584
    234
    A hermetic seal is a fluid-tight glass-to-metal bond. Gasses and liquids cannot penetrate the diode and contaminate it.
    Ken
  10. crutschow
    Mar 14, 2008
    13,505
    3,378
    Look up the meaning of hermetic if you don't know. :rolleyes:
    shortbus and ErnieM like this.
  11. GopherT
    Nov 23, 2012
    6,320
    4,044
    What do you mean, "look up the meaning"?:rolleyes:
    shortbus likes this.
  12. ErnieM
    Apr 24, 2011
    7,440
    1,627
    GopherT likes this.
  13. crutschow
    Mar 14, 2008
    13,505
    3,378
    You've never heard of Google or a language dictionary? :confused: Are you related to Dexter?
Thread Status:
