I'm not sure about the Airbus A380, but it looks like the main gear trucks are castered, which allows them to align with the aircraft's direction of travel as the rear tires in the truck make ground contact.The article claims this aircraft landed "sideways"... although it seems a little exaggerated to me, it's still pretty impressive:
http://edition.cnn.com/videos/world...r?iid=ob_homepage_showcase_pool&iref=obinsite
Absolutely standard operating procedure.The article claims this aircraft landed "sideways"... although it seems a little exaggerated to me, it's still pretty impressive:
Oh my... and the camera was at an angle to the runway!... check out a B-52 landing in a crosswind!
http://www.skilledpilots.com/video-...g-a-parachute-and-slowing-down-on-the-runway/
When I lived in Newport Beach they were hell on noise abatement. They would hold it at the end of the runway until it quivered like a new puppy, take it up as steep as they could then drop everything including your stomach. You almost always heard a gasp from a first time passenger.I was waiting at runway 16 for take off clearance at Renton, WA (KRNT), when the tower cleared a brand-new, fresh-out-of-the-Boeing plant, 757 to take off on runway 34 (opposite direction on the same runway). I understand that as these aircraft roll off the assembly line, they do not yet have any interior (seats, fittings, etc), and they put just enough fuel in them to ferry them to where-ever the production process is finished. The runway is short, and they pull into what appeared to be about a 40degree deck angle to climb rapidly for noise abatement. It sure looks impressive when the take-off roll is directly toward you. I'm thinking that the 757 was more than 2000ft agl when it went over me. Not bad off a runway that is only 5380 ft long.
Which driver? ... what a horrible crash!Hello,
I am glad not to be the driver here:
http://www.telegraaf.nl/tv/nieuws/buitenland/28047027/__Automobilist_overleeft_horrorcrash__.html
Bertus
When I go to the site I get a pop-up in a foreign language with no obvious way to close it -- I'm not going to click on some button to see what happens since I don't want to give it permission to load a bunch of crap on my machine.Hello,
Bertus
Will following these steps result in them putting cookies on my machine? If so, then I will pass.Hello,
@WBahn
The Telegraaf uses cookies.
Due to european rules they must ask the user if the cookies may be used.
You can reduce the use by using the grey button (meer informatie) on the first pop-up.
Then choose the most right grey button (functioneel) and press the green button on the bottom (akkoord).
When you use add-block plus, an other pop-up will appear, but just press the blue text on the bottom to continue.
Bertus
Thread starter | Similar threads | Forum | Replies | Date |
J | About Parasitic Amp Draw (Battery Drain) in a passenger car. | General Electronics Chat | 21 | |
J | Drone Hits Passenger Jet | Off-Topic | 10 | |
I am so glad I am not one minute faster | Off-Topic | 14 | ||
J | Elevator (passenger lift) call collective. | General Electronics Chat | 22 | |
W | Glad I found Ya'll!! | General Electronics Chat | 15 |
by Aaron Carman
by Duane Benson
by Aaron Carman
