yes hp1729, now i have to write out all of the 16 functions and i don't know if i am doing it correctly when you have Xy+xy’+xy’+xy for a table would it be 1, 1, 0, 0?
It would really help if you made an attempt to actually make a table, even if it is a partial table.yes hp1729, now i have to write out all of the 16 functions and i don't know if i am doing it correctly when you have Xy+xy’+xy’+xy for a table would it be 1, 1, 0, 0?
There is a [TABLE]blah blah [/TABLE] tag pair you can use. For some reason it is not documented in the basic BB Code Help screen (it's probably a third-party add on). There's lots of help online about it.is there an insert table i didn't see one sorry about that
x y ƒ1
1 1 1
1 0 1
0 1 1
0 0 1
This is fine.x y ƒ1
1 1 1
1 0 1
0 1 1
0 0 1
now i have to find out what minterm fits that function and how i was doing it was just putting in their compliments i think that is how i was doing it, for example Xy+xy’+x’y+x’y’ is what i put in for ƒ1
Well, what does the Boolean Basics article say about that?So is * the same as ^ and + is the same as v in boolean expressions?
In the symbols page in the text editor is a plus sign with a circle around it that is often used in mathematical literature to represent exclusive-or. I believe I used it in my example (post #12):Well, what does the Boolean Basics article say about that?
Note that the carat '^' is not quite the same as the logic conjunction symbol
\text{\^} \; \text{vs.} \; \wedge
But for people using the math symbols with a standard keyboard, that's what they use.
However, for people using the engineering conventions, we use the carat to mean exclusive-OR.
So you need to be aware of the context of where you see it.
The TS appears to just be using text-based symbols.In the symbols page in the text editor is a plus sign with a circle around it that is often used in mathematical literature to represent exclusive-or. I believe I used it in my example (post #12):
x ⊕ y means "x exclusive-or y". This function is true if x = 1 or y =1, but is false if x = y.
The only computer language I can think of might be Iverson's APL since it was based on selectric typewriters with interchangeable balls.The TS appears to just be using text-based symbols.
I have never found a key board that has the + symbol surrounded by a circle.
They might well exist.
I'm also not aware of a programming language that has that symbol in its source alphabet, but again one might well exist.
The plus-with-circle is definitely useful for hand-written stuff and is often used in engineering texts and publications. I don't know about math literature, but I believe that formal logic has a different symbol for what we call exclusive-OR, namely \(\veebar\).
Interesting. So how was the source code stored? It would have to have encode which ball was used for a given character (or so it would seem).The only computer language I can think of might be Iverson's APL since it was based on selectric typewriters with interchangeable balls.
Or are you saying that there was one particular ball that was always used for APL programs?Interesting. So how was the source code stored? It would have to have encode which ball was used for a given character (or so it would seem).
