Given i(t), Find q between t=0s and t=0.01s
Discussion in 'Homework Help' started by Eng.Mubarak, Sep 24, 2011.
  1. Eng.Mubarak
    Oct 9, 2010
    7
    Hello
    Problem :
    i(t) = 10 sin(200 pi t)
    Find q between t=0 s and t=0.01s
    I know that it is a straightforward problem.
    q=integration of i(t) from t=0 to t=0.01
    The problem here is that the value of the integral equal zero!
    q = 10 integration of ( sin(200 pi t) ) from t=0 to t=0.01
    = ( - 10 / 200 pi ) [ cos(200 pi t) ] from t=0 to t=0.01
    = ( -1 / 20 pi) [ cos( (200) (0.01) pi ) - cos(0) ]
    Now the big problem is what is pi ?!!
    is it 3.14 or 180 ?
    Our T.A. said that if your calculator is in degrees, then pi=180
    and if it is in radians, then pi = 3.14
    My calculator is in degree, so i will put pi = 180
    but this give me zero !
    Any help?
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    0 is a valid answer. It means that the total load in coulombs that has entered your device over the given time period is zero. In other words, as much load has got in, that much current has got out. It shouldn't startle you so much.
    If you want to find how much load has gone in AND out of your device, you should calculate the integral of the absolute value of the current. Then your answer won't be zero.
  3. Eng.Mubarak
    Oct 9, 2010
    7
    Thanks.
    What about pi?
    is my T.A right?
  4. edgetrigger
    Member
    Dec 19, 2010
    133
    19
    i(t) = I sin( ωt)
    ω = 2∏ft ; if f is in hertz, t in secs than ∏ = 3.14
    you need to substitute 3.14 not 180 for value of π
  5. Eng.Mubarak
    Oct 9, 2010
    7
    We did not learn f or omega.
    this is the first lecture in this course.
    What I know is I = dq / dt
    and i want to find q given i(t) by integration.
    my question is while i evaluate the integral, pi is 180 or 3.14 ?
  6. Georacer
    Nov 25, 2009
    5,151
    1,266
    It really depends on what your calculator accepts. Use pi if the calculator says that sin(3.14)=0 or 180 if you get sin(180)=0.
