I want a circuit that works as a duel charger(600-800 watt)Inverter AC & Solar Parallel And If possible Need Separate Circuit of Solar Charging with battery full charging Controller with auto cut and if need after solar charging battery itself can get charge form AC.Basically Add on Circuit that be integrated with existing 600-800 watt Inverter used 12v 180Ah Inverter battery.Its Need if possible solution.
Reply
Reply
