GFCI Fire
Discussion in 'General Electronics Chat' started by mr_steve_fisher, Apr 19, 2012.
  1. mr_steve_fisher
    Apr 19, 2012
  2. MrChips
    Oct 2, 2009
    12,633
    3,453
    20A is a lot of current to pass in such skinny wires. I would go for 14AWG or 12AWG.
  3. gerty
    Aug 30, 2007
    1,154
    304
    What was plugged into them when it happened?
    How much current was being drawn at the time?
    How long are the wires feeding the GFCI?
    Was there an extension plugged into the GFCI to the load?
    This will help us answer your questions..
    20amps = 12 ga wire
  4. Ron H
    Apr 14, 2005
    7,050
    657
    Where did you find the wire size that is incorporated in this device? I couldn't find it.
    PackratKing likes this.
  5. Ron H
    Apr 14, 2005
    7,050
    657
    Yeah, if they had it plugged into a 50amp circuit, and it had a 40 amp load, it might catch on fire. I know I would.:D
  6. mcgyvr
    Oct 15, 2009
    4,789
    975
    It comes with 12/3 wiring (12 AWG, 3 conductor) pigtails or with mating plugs pre-installed.
    I'd guess you seriously overloaded the device (load far exceeding 20A)..
    YOU NEED A QUALIFIED ELECTRICIAN NOW.
  7. crutschow
    Mar 14, 2008
    13,496
    3,373
    A GFCI is not a circuit breaker for overloads so it will carry whatever current you put through it until it fries.
