thatoneguy
- Joined Feb 19, 2009
- 6,359
I can do the fine pitch single sided when using the laminator, but not with the iron method (uneven pressure/heat squishes the toner around).Many people get reliable results with homemade boards, either photo or laser print, with 10/10mil DRC. I do 12/10 using photo-etch. Double-sided is not a big step from there.
The jump between that and getting perfect registration for the same detail level between two sides in one etching session is a big jump.
I've had several where vias were centered on one board at one edge, and on the edges of the pad at the other corner of the board. Once the via count gets over 10 or so, I don't trust myself, and a board would probably arrive with solder mask, vias, and screen by the time I ruined 4 boards to get perfect alignment.
Others with more practice of DIY double sided, or even multilayer DIY boards with far more patience than I cultivated are able to get amazing performance. It is a huge matter of practice and the exact methods, which vary between people who do the toner transfer method.
Yes, Photo boards are much easier to "get right", but also have more steps/material cost per board. Again, it's a personal choice, some like the Zen of making their own board, solder mask, vias, etc. I usually just want to get the hardware together to debug the software.
