Getting steady current with no ripples using LM317
RG23
Joined Dec 6, 2010
304
I am trying to use LM317 as current regulator but still could not manage to get ripple free current at its output.
Can anyone guide me in this?
ErnieM
Joined Apr 24, 2011
8,377
Yep, post your schematic.
How much ripple is too much?
How much ripple is at the input? If the input is not high enough the output will drop with the input.
MikeML
5,444
How big is the filter capacitor upstream of the LM317?
How much voltage across the load?
Enough of the questions,
Just post the schematic!
dl324
Joined Mar 30, 2015
16,921
We can't even be certain that there is a filter cap... 300 posts and still doesn't know to post a schematic??
Roderick Young
Joined Feb 22, 2015
408
You have the LM317 wired in constant current mode, right? What size of inductor is in series with the output, if any? Do not put a capacitor on the output for filtering. As the others have mentioned, it's really to your benefit to post a schematic. Hand drawn is fine, or you can do one in a drawing program if you like. Or if you took the circuit from elsewhere on the web, give us a pointer to it.
DickCappels
Joined Aug 21, 2008
10,179
LM317's only have a finite ripple rejection ratio. If you need even more, try preceding the LM317 constant current source with a fixed DC voltage regulator. It worked for me in one product.
dannyf
Joined Sep 13, 2015
2,197
Your question cannot be answered unless you specify the levels of ripples you are willing to live with, as any real circuit will have ripples no matter what you do. You can minimize it but not eliminate it.
cmartinez
Joined Jan 17, 2007
8,253
Interesting. But wouldn't it be better to use a voltage reference and then boost its output with a bipolar transistor?
Of course the OP wants to use an LM317, but I wonder if he'd be open to a different approach.
