Hi all,
I'm trying to get started with using SPICE for simulations and had questions on how the AC Sweep works.
To start (and for simplicity sake), I'm using a very basic common emitter circuit. For the transient test, I am applying a 0.1 V amplitude, 1kHz sine wave on top of a 0.8 V DC source. I can then plot VIN and VOUT to see how the circuit is behaving.
When I run the same setup using the AC source to do an AC Sweep, I see that at 1kHz, I get a gain of -41. How is this gain being calculated at each frequency? Why is the gain negative?
If I use the above transient plots, picking an arbitrary point, I can calculate:
gain= 20 * log(VOUT/VIN) = 14.71
Now, I know this probably isn't right, but this is where I am currently stuck. So I defer to the experts
I really would like to understand more of what's going on. Especially on a qualitative level.
Thanks much!
Thanks much!
