Getting Started on Programming a PIC
Discussion in 'Embedded Systems and Microcontrollers' started by sbf2009, Jul 21, 2010.
  1. sbf2009
    Jul 21, 2010
    8
    I have a PIC16F877A I need to program for a project. I am completely lost on how to get/setup an IDE to work with. I can't even get this bit of example code to compile correctly on MPLAB.
    #include <16f877A.h>
    #device ICD=TRUE
    #fuses HS,NOLVP,NOWDT
    #use delay (clock=20000000)
    #define GREEN_LED PIN_A5
    void main ()
    while (TRUE)
    output_low (GREEN_LED);
    delay_ms (1000);
    output_high (GREEN_LED);
    delay_ms (1000);
    I think I specified which type of PIC I was using, but I'm not sure if I did it right. If anyone could hold my hand to help me get an environment I can work in correctly, I would much appreciate it.
  2. ELECTRONERD
    May 26, 2009
    1,146
    16
    What compiler are you using?
  3. Vaughanabe13
    May 4, 2009
    102
    5
    Where did you get that example code? If you're planning on using Microchip's C18 compiler that code will not compile. Are you using a development board for your PIC or do you have a custom board that you made for it? We need a lot more information on what you are doing/trying to do before we can give good advice.
  4. sbf2009
    Jul 21, 2010
    8
    I'm using CCS's PIC16F877A ( http://www.ccsinfo.com/product_info.php?products_id=16F877Akit ), but I was not given the Compiler CD that comes with the full kit. I just need to be able to compile code and send it out to the PIC.
    I tried using MPLAB with CC5X, the code wouldn't compile, I don't think it could even find the 16f877A.h header.
    The example code came from the exercise booklet that said the compiler CD was optional, so presumably I should be able to use other software to program for it.
  5. sbf2009
    Jul 21, 2010
    8
    Bumping to try and get a response.
