getting more power to my LEDs
Discussion in 'The Projects Forum' started by sandiegoman, Sep 20, 2013.
  1. sandiegoman
    Sep 9, 2013
    7
    I built this simple color organ and swapped out the standard LEDs with 3.2-3.4v, 100-120ma LEDs. It worked pretty good, but then I decided to remove the resistors between the LEDs and they got a little brighter.
    http://www.instructables.com/files/orig/FKQ/ZKWQ/GQ5PYWHF/FKQZKWQGQ5PYWHF.pdf
    The weird thing is that the LEDs at the end get way brighter than the rest. I even tried removing the 2.2k resistor and swapping them out with 1k resistors.
    http://www.instructables.com/file/FIEOAVUGQ5PWB21
    I have made all the LEDs the same color, and definitely the ones to the right of the board light up quite a bit brighter than the rest.
    Any ideas on how I can fix this to make them all equally as bright? I am using 12v.
    Thanks!
    Bryan
  2. #12
    Nov 30, 2010
    16,705
    7,358
    Increase the resistance of the resistor that is presently marked as 270R.
  3. sandiegoman
    Sep 9, 2013
    7
    I am not looking to dim the ones on the right, but make the ones on the left brighter. There is a significant brightness difference.
    Any other ideas?
  4. mcgyvr
    Oct 15, 2009
    4,798
    979
    The resistors that set the LED current (aka brightness) are the
    100 ohm for the high channel
    180 ohm for the mid channel
    270 ohm for the low channel
    To increase brightness you use a lower resistance value.
    AND if they are all the same LED's and the same number of LED's in each channel then all 3 resistors should be the same rating to achieve the same brightness across all 3 channels.
  5. sandiegoman
    Sep 9, 2013
    7
    I completely removed those resistors and put jumpers in their place, they definitely got brighter, but the far left ones are WAY dimmer than the others and definitely appear to be underpowered for some reason.
  6. mcgyvr
    Oct 15, 2009
    4,798
    979
    PUT THE RESISTORS BACK.. LED's MUST have current limiting resistors.
  7. sandiegoman
    Sep 9, 2013
    7
    I understand this, but why would the LEDs be getting different amounts of current and how can this be fixed? Thanks for all your help in this, I really appreciate it.
  8. mcgyvr
    Oct 15, 2009
    4,798
    979
    You fix it by putting the resistors back into the circuit.
    Without current limiting resistors each string will/can draw different currents based on slight differences in forward voltages/wire resistance,etc... thus causing 1 string to draw more current than the others. The resistors "set" the current to the value you want.
  9. sandiegoman
    Sep 9, 2013
    7
    I see. So if I fiddle around with those, I should be able to get them equally bright?
  10. mcgyvr
    Oct 15, 2009
    4,798
    979
    Yes those resistors set the current for each channel. Adjust them and brightness will adjust accordingly. BUT they must be there.. No "jumpers"
  11. Metalmann
    Dec 8, 2012
    700
    223
    I'm no expert witness, ;) but check each/every, LED and resistor separately, then combine them to get the closest in equal brightness.
  12. #12
    Nov 30, 2010
    16,705
    7,358
    This is a frequency controlled circuit. The brightness of the high frequency section is controlled by how much high frequency energy is being put into the input. If you want all the LEDs to be the same brightness, play music that has the same amount of high frequency sounds as it has low frequency sounds.
    wayneh likes this.
