Getting error in the code
Discussion in 'Programmer's Corner' started by namratha_r, Mar 20, 2015.
  1. namratha_r
    Jan 27, 2015
    23
    Code (Text):
    1. void PWM_Set_duty( uint16_t duty_cycle, uint16_t timer_prescalar )
    2. {
    3.      uint16_t reg_value;
    4.      float frequency;
    5.      frequency  = (_XTAL_FREQ/2);
    6.      frequency  = (frequency/timer_prescalar);
    7.      frequency  = (frequency/(PR2+1));             // FREQUENCY OF PWM SIGNAL
    8.
    9.      frequency  = (frequency*100)/(duty_cycle);
    10.
    11.      reg_value  = (_XTAL_FREQ)/(uint16_t)(frequency);
    12.      reg_value  = (reg_value/timer_prescalar);
    13.      OC1RS      =  reg_value;
    14.      OC1R       =  OC1RS;
    15. }
    PWM_Set_Duty.c:13:29: error: expected ')' before 'duty_cycle'
  2. MCU88
    Member
    Mar 12, 2015
    360
    35
    Hello....
    An C compiler will produce 1,000 errors from an missing ; or } etc ... So your problem would be anything.
    You need to step through the code to debug it...
  3. namratha_r
    Jan 27, 2015
    23
    actually am getting error in this function prototype... and am unable to solve this
    Code (Text):
  4. ScottWang
    Aug 23, 2012
    4,924
    777
    What't the relationship between (uint16_t) and (frequency) ?
    Are you missing '*' or '/' or ... ?
  5. namratha_r
    Jan 27, 2015
    23
    first i have initialized frequency as float type . then am doing type casting for frequency by changing into unsigned int and finally loading the value into reg_value
    Code (Text):
  6. namratha_r
    Jan 27, 2015
    23
    Code (Text):
    1. void PWM_Set_duty(int uint16_t duty_cycle, int uint16_t timer_prescalar )
    i cant declare this two integer outside the prototype because in the main programming i will be loading some values to this
  7. ScottWang
    Aug 23, 2012
    4,924
    777
    Try to delete two spaces in the brackets.
    void PWM_Set_duty(uint16_t duty_cycle, uint16_t timer_prescalar)
  8. namratha_r
    Jan 27, 2015
    23
    i solved the problem ... i did not include that prototype function that was the error
  9. ScottWang
    Aug 23, 2012
    4,924
    777
    As this?
    void uint16_t PWM_Set_duty( uint16_t duty_cycle, uint16_t timer_prescalar )
  10. namratha_r
    Jan 27, 2015
    23
    void uint16_t PWM_Set_duty( uint16_t duty_cycle, uint16_t timer_prescalar );
