Getting a PWM to analog -5 and +5
Discussion in 'Analog & Mixed-Signal Design' started by Ah Pek, Sep 20, 2004.
  1. Ah Pek
    Sep 20, 2004
    Any suggestions on how I can get use a PWM signal and build a simple circuit to output -5 to +5 that is nice and smooth?
    If it helps I have two PWM outputs I can use and using the PICAXE 28x I can program any period and duty cycle.
    Cheers
    Ah Pek
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If you don't need any current-carrying capacity, then the PWM output set to 100% duty cycle should give the +5. If this is the case (I am not familiar with this model PIC) then adding a inverting charge pump like the 7660 puus two 10 uF tantalum caps will give you the -5. As I said, don't expect to power anything with this setup.
