Getting 5.35V from a LM2675-5
Discussion in 'General Electronics Chat' started by spinnaker, Dec 29, 2015.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,063
    1,160
    I am getting 5.35V (loaded) from a LM2675-5 from the PCB I just created. My Pic simply will not tolerate the over voltage.
    I bread boarded the same circuit and I am getting 4.97V from the bread boarded circuit. I placed the chip in the PCB in the bread board and it gives me the 4.97V too.
    Any ideas what could cause this over voltage?
  2. GopherT
    Nov 23, 2012
    6,300
    4,020
    This chip seems to need a 20 mA minimum load. Are you consuming enough? Try adding a 100 ohm or 220 ohm resistor to the load (in parallel to your existing load).
  3. spinnaker
    Oct 29, 2009
    5,063
    1,160
    Well as I mentioned work fine on the breadboard and that is no load (not the module but a separate complete circuit). When the new module is plugged in, it is powering a LCD with backlight and a pic so it must be consuming at least 20 ma.
    I thought maybe the feedback was not connected but I just measured 6.3V there.
  4. GopherT
    Nov 23, 2012
    6,300
    4,020
    Weird. Maybe a bum part?
  5. spinnaker
    Oct 29, 2009
    5,063
    1,160
    Nope. Stuck the chip into the breadboard and it works like a champ. Bad diode maybe? Or error in designing the board but I have been over it and I do not think so. If it was the coil I should think it would not work at all. There really is no much that can go wrong.
    This is what it says about the diode. Not sure if that has anything to go with my issue.
  6. GopherT
    Nov 23, 2012
    6,300
    4,020
    Which diode are you using? Is the diode fast enough for that regulator?
  7. spinnaker
    Oct 29, 2009
    5,063
    1,160
    1n5819
  8. MrAl
    Distinguished Member
    Jun 17, 2014
    2,548
    512
    What inductor are you using on each board? (Maybe a link)
    If an inductor saturates for a little part of the cycle it can cause all kinds of problems.
    Also, check the ground paths from input to chip and from chip to output.
    Is there any way you can post a picture of the PC Board layout?
    You do have to be a little careful about the placement of the feedback trace relative to the inductor mounting.
    Since you have a test bed that is working, you can try swapping inductors and/or diodes. If swapping the inductors for example produces the opposite effect in each circuit then you know one of the inductors is not quite right. If there is no change for any swap then it must be the layout.
  9. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    Also, is the feedback line far enough from the inductor?
    From the datasheet:
    Bertus
  10. spinnaker
    Oct 29, 2009
    5,063
    1,160
    That must be it! I have the output going right under the inductor! What is the best way to fix this? (Other than move the trace from out under the inductor).
    How would I accomplish this?
    "ground plane construction or single point grounding."
    I need to learn to read the whole datasheet. :oops:
    They provide a sample below using surface mount. Just follow it as close as possible? I am not sure what I am looking at in the first image. Not really sure of the second. Which are the traces? Why are the caps so far from the chip (I realize it is 4x)?
  11. spinnaker
    Oct 29, 2009
    5,063
    1,160
  12. ISB123
    May 21, 2014
    1,240
    531
    Shield it and connect the shield with GND.
  13. spinnaker
    Oct 29, 2009
    5,063
    1,160
    So how do I shield it? Do I buy shielded inductors or make my own? How would I make my own shield? Will a bit of aluminum foil do?
  14. spinnaker
    Oct 29, 2009
    5,063
    1,160
  15. ISB123
    May 21, 2014
    1,240
    531
    Those don't need to be connected to the ground since they are encased in ferrite. You could try making a shield from alu. foil and then just bolt it down to GND.
  16. spinnaker
    Oct 29, 2009
    5,063
    1,160
    I think I might just bite the bullet and buy those. Foil would look a bit funky. Darn I was going to do that when I purchased the parts for this project but figured it was over kill. Thanks for the help.
  17. spinnaker
    Oct 29, 2009
    5,063
    1,160
    I redesigned the PCB. I isolated the coil off to the bottom left, widened the traces and reduced the space taken by that diode. I added a pad to ground near the coil in case I want to add a makeshift shield. The connector is flipped from the last one because I had to put the pins on the trace side of the board.
    Image is increased in size to 429%.
  18. ISB123
    May 21, 2014
    1,240
    531
    Looks fine although I would move GND trace completely on other side so its not even remotely close to the inductor.
  19. spinnaker
    Oct 29, 2009
    5,063
    1,160
    I was thinking about that myself. I need to worry about board width. It would have been problematic to wrap it around the other side and I would need a jumper anyway.
    How is this for a compromise? It let me move the inductor out just a little bit more.
  20. ISB123
    May 21, 2014
    1,240
    531
    Should be perfect now.
