Hi. I was working on a class project and some parts of the schematic required a 18VDC regulated voltage and the other partes required a 12VDC regulated voltage and I have a 120VAC to 18VAC center center tapped transformer (so I have two 9VAC outputs) (see image posted below). My question is: instead of using two separate transformers, can i connect one circuit to the 18VAC (using the two side wires) and the other circuit to 9VAC (using the center wire and a side wire)? is there any misunderstood concept that may limit that kind of configuration?
P.D.: Current consumption is not a problem because the sum of both circuits' consumption is about 800mA. Also, I understand the concept of RMS and that's the reason I know i can obtain 12VDC from a 9VAC RMS output.
Thanks in advance!
Thanks in advance!
