Get 12 bit parallel data converted to serial data.
Discussion in 'The Projects Forum' started by Blangdk, Aug 21, 2014.
  1. Blangdk
    Aug 21, 2014
    16
    Hi Guys,
    I need to have a 12 bit parallel image data signal converted to a serial data signal so I can send it through a fibre optic cable.
    Any good suggestion to how I might go about doing this?
    Cheers.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    With a Parallel In Serial Out (PISO) shift register.
  3. Brownout
    Jan 10, 2012
    2,375
    998
    You can do this with most any micro-controller.
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    What data rate?
  5. Blangdk
    Aug 21, 2014
    16
    Thanks for your replies.
    MikeML > What do you mean by the data rate? The FO data rate?
    I have been looking at different micro controllers, but that's a minefield on it's own to find the right one, but I'll keep looking.
    Cheers.
  6. MikeML
    Oct 2, 2009
    5,451
    1,066
    Most fiber optic communications systems run data rates > 100Mbits per s. You will be hard pressed to do more than 1Mb/s with a microcontroller. Even a parallel in/serial out shift register chips wouldn't do more than 10Mb/s. Then there is the bandwidth limitations of the LED to send, and a photodetector to receive...
  7. Blangdk
    Aug 21, 2014
    16
    Cheers MikeML
    I hadn't thought about the FO data rate at all. I assumed that it would just feed through, whatever data signal I would feed into it.
    Any good ideas how to get around this?
    Surely it is possible to get a 12 bit video signal through fibre optic.
  8. Blangdk
    Aug 21, 2014
    16
