Gerbv rendering question
Discussion in 'General Electronics Chat' started by buzaiandras, May 6, 2012.
  1. buzaiandras
    Jul 18, 2011
    54
    I have a question about viewing gerber files with Gerbv.
    I opened some gerber files using Gerbv 2.6 under Windows XP and they look like the one in the attached image. They have some horizontal black lines (which are not present in the original design).
    My question is: does anybody else encountered this issue with Gerbv? Is this a Gerbv rendering issue or it will affect the fabrication of the board?
    Note: sometimes when I zoom in or out the black lines disappear.
    Thank you,
    Buzai
  2. kubeek
    Sep 20, 2005
    4,688
    806
    I use Gerberlogix to check my gerbers. I think it is just a rendering issue, but you should still try a different viewer just to check. Anyway it seems to be just an artifact on the polygons, so different width/spacing should get it sorted.
    Anyway I would not be worried about them appearing on the actual board, it looks way too thin to pass the photoprocess.
  3. ErnieM
    Apr 24, 2011
    7,436
    1,625
    I hate rendering artifacts like this too, as the board is also a rendered object. So I keep several viewers on hand, and if the artifact isn't on screen for all of them I assume it isn't going to be on my final board.
  4. Potato Pudding
    Jun 11, 2010
    684
    92
    Those look like patterning in the copper pour to me.
    As evidence they seem to stop before they could make a connection to the isolation routing.
    That type of patterning is an intentional design practice meant to minimize eddy currents - much the same as transformers use laminated cores.
  5. buzaiandras
    Jul 18, 2011
    54
    Thank you all.
    I just noticed that if I view the gerber files with Gerbv under Linux (Ubuntu 11) the black lines are not shown at all. No matter if I zoom in or out.
    I will try some other gerber viewers just to make sure there is no problem with my board.
    @Potato Pudding: the board was designed by me and I did not create the patterning on purpose :).
  6. Potato Pudding
    Jun 11, 2010
    684
    92
    I don't know what design software you used or the settings in that software and design.
    I thought it might be unintended on your part, with the patterning added by your software.
  7. buzaiandras
    Jul 18, 2011
    54
    I understand :). Thank you.
    For the board layout I used Eagle (free edition).
  8. buzaiandras
    Jul 18, 2011
    54
    I just checked the gerber files with two other viewers (GerberLogix 2.7 and GC-Prevue 20.2.6) and they seem to be fine.
    It seems that the rendering artifacts only occur with Gerbv on Windows.
    Thank you all :)
  9. dondonker
    May 8, 2012
    Hi it's my pleasure to be here, I'm dondonker and i just wanna tell you that I'm so happy to be here. Any way do you know electronics circuit design?
