Geophone with sound
Discussion in 'The Projects Forum' started by geophone, Apr 6, 2013.
  1. geophone
    Apr 6, 2013
    I've made up a BG MIcro Geophone kit. I also want to add sound to it with one of those little kit buzzer speakers.
    I've tried around the board but I'm failing to find a location I can connect it to so when the LED's light up the buzzer can sound.
    Can someone please help and have a look at it here http://www.bgmicro.com/pdf/kit1019.pdf
    and advise me of a good spot for it?
  2. antonv
    Member
    Nov 27, 2012
    149
    27
    How do you want the sound to work? Should it turn on at a certain level or should it change as the level increases?
  3. geophone
    Apr 6, 2013
    I would happy for it to to make a sound when it lights up the first LED.
  4. antonv
    Member
    Nov 27, 2012
    149
    27
    How about a circuit like the one I attached.
    I don't know how much current your buzzer requires. You may have to reduce R1's value to get Q1 to turn on all the way (<0.5 V across its collector and emitter).
    Q1 has a maximum collector current of 600 mA but I would not use it for more than 400 or 500 mA.
  5. geophone
    Apr 6, 2013
    Thanks Antonv.
    The little buzzer says 12v but makes noise with 1 AAA of 1.5v
