generator
Discussion in 'General Electronics Chat' started by akifnadeem, Jan 9, 2012.
  1. akifnadeem
    Apr 9, 2010
    15
    i have problem on my generator that gets shut down giving alarm of low voltage . what cause could it be ?
  2. crutschow
    Mar 14, 2008
    13,475
    3,362
    Since you haven't told us the type of generator it is or how it is being used we could only make wild guesses as to the problem and that's not productive. We need more info.
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    A wind powered generator (windmill) and the wind stopped blowing?
  4. akifnadeem
    Apr 9, 2010
    15
    its diesel generator
  5. thatoneguy
    Feb 19, 2009
    6,357
    718
    When was the last time it was run?
    Some need to be run periodically to keep the rotor magnetized.
    Long shot, but is this an inverter type generator? (built in last 3 years or so)?
    Diesel engine runs fine, generator does... what? (explain in detail, also post make and model number of genset)
  6. akifnadeem
    Apr 9, 2010
    15
    its puma cummins . it has been in running condition since 5 years. run in parallel with other generators.
  7. thatoneguy
    Feb 19, 2009
    6,357
    718
    Has anything changed since the last time it worked?
    You'll need to give us a bit more info, and may photos, but all our guesses will be shots in the dark without knowing more aobut it, how it quit, etc.
  8. hhhunzai
    Member
    Nov 14, 2011
    72
    Please elaborate your problem.
    Have you checked Its rpm? have you checked its maintenance hours? have you checked its voltage manually with a voltmeter on its output MCCB or breaker?
    Please ease us by doing these tests.
    If you have checked these problems, then look into you generator control relay how much voltage it shows on it display?
