Generator Synchronization - Need advice on phase measurement
Discussion in 'The Projects Forum' started by kickurshin, Nov 6, 2010.
  1. kickurshin
    Nov 6, 2010
    Good evening everyone, I've often lurked these forums but never posted until now.
    I am designing a single phase generator synchronization system for my college technical report. My mentor wants me to do an entirely digital system. I am in the preliminary planning stages and I am unsure how to measure the phase difference between the line and generator voltage.
    I was thinking of converting the ac waveform to a square wave so that I may calculate the time difference between the rising edge of each waveform.
    I was simply looking for suggestions to implement this design, thanks for your time, I look forward to contributing what I can to this forum!
    Cheers,
    -kickurshin
  2. sceadwian
    Jun 1, 2009
    499
    37
    A simple rectifier will do that just fine.
  3. CDRIVE
    Jul 1, 2008
    2,223
    99
    Think 'Zero Crossing Detector' instead.
  4. kickurshin
    Nov 6, 2010
  5. thatoneguy
    Feb 19, 2009
    6,357
    718
    You would need an isolation transformer for safety.
    A Step down transformer and a phase detection IC would work nicely.
  6. sceadwian
    Jun 1, 2009
    499
    37
    kickurshin, the diode used in that circuit makes it a half wave rectifier...
    The circuit depicted will work just fine it gives you isolation from the AC line as well.
    thatoneguy, the circuit he linked uses an opto isolater, that provides isolation.
  7. kickurshin
    Nov 6, 2010
    My mistake, that was a pretty late post! Thanks for your help everyone.
