I need help designing an automatic generator set start circuit to be run from a remote transfer switch. The switch sends a two wire "close" signal to start the generator and "opens" to stop it. The generator requires a momentary close on wire 1 and 3 to start and a momentary close on wire 1 and 2 to stop. Wire 1 is engine ground. The current required is only enough to run relays. 120VAC is available at the transfer switch when the generator is off. 12VDC is always available at the generator and 120VAC is available when it runs.
