generating sine wave
Discussion in 'The Projects Forum' started by elengr, Jun 28, 2011.
  1. elengr
    Feb 5, 2011
    15
    I am working on pure sine wave inverter. My skills are of beginner level. Will integrating a triangular wave form a sine wave?
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Did you already think of SPWM (sinusoidal pulse width modulation) ?
    Here is a page from the EDUCYPEDIA with several links on the subject:
    SPWM
    Bertus
  3. wayneh
    Sep 9, 2010
    12,375
    3,226
    Nope. Do the math. Integral of cosine is sine.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
  5. CDRIVE
    Jul 1, 2008
    2,223
    99
    One of the function generators that Heathkit produced in the 70's produced a square, sine and triangle. All three were formed by the triangle osc.
  6. someonesdad
    Jul 7, 2009
    1,585
    141
    A triangle wave is a collection of straight lines and the integral of a straight line is a quadratic. But Bill's right -- it's a pretty good fit to a sine wave. Here's some python/numpy/matplotlib code that generates the attached plot that shows you qualitatively what's going on:
    Code ( (Unknown Language)):
    1.
    2. from __future__ import division
    3. from pylab import *
    4.
    5. n, num_periods = 1000, 3
    6. # Create square wave
    7. y = zeros(n//2) + 1
    8. y = concatenate((y, zeros(n//2) - 1))
    9. # Show a few periods
    10. y = concatenate([y]*num_periods)
    11. # Plot
    12. plot(y, label="Square wave")
    13. y = cumsum(y)
    14. y /= max(abs(y))/2
    15. range = max(y) - min(y)
    16. y -= range/2  # Center it symmetrically about the x axis
    17. plot(y, label="Triangle wave")
    18. y = cumsum(y)
    19. y /= max(abs(y))
    20. plot(y - 0.05, label="Integrated triangle wave (offset a bit)")
    21. # Subtract from a sine and plot the difference
    22. t = arange(0, 2*pi, 2*pi/n)
    23. t = concatenate([t]*num_periods)
    24. y1 = -sin(t)
    25. plot(y, label="True sine")
    26. diff = y - y1
    27. plot(diff, label="Integrated triangle minus sine")
    28. legend(loc="upper left")
    29. ylim(-1.1, 2.2)
    30. title("Integrated Triangle Wave")
    31. grid(True)
    32. show()
    33.
    Note I had to offset the integrated triangle wave a bit -- otherwise the two become nearly indistinguishable.
  7. wayneh
    Sep 9, 2010
    12,375
    3,226
    Interesting, thanks. That's a lot better than I guessed.
  8. someonesdad
    Jul 7, 2009
    1,585
    141
    What was interesting was that I was going to roast Bill for making such a dumb statement. But then I thought I should check it out first. After writing that script, I had a strange feeling of deja vu. Then it slowly dawned on me that two or three decades ago I remember being a bit of a disbeliever when someone else made the same comment and I had to see if it was true. I had forgotten all about it.
    That, of course, is the canonical definition of experience: it lets you recognize that you just made the same dumb mistake again. :p
  9. KJ6EAD
    Apr 30, 2011
    1,426
    363
    I ran across this very multiple diode clipper triangle to sine conversion a while back: http://www.falstad.com/circuit/e-sinediode.html. It made me smile because there's so many parts. I guess you could use Germanium diodes and even more stages to get a better approximation of a true sine wave. ;)
  10. wayneh
    Sep 9, 2010
    12,375
    3,226
    Hah! What a concept; think first, flame second. :p
    Your comments on experience ring true. More than once in my career I found myself working on something vaguely familiar. Digging into my files would uncover that I had solved the same thing 5-10 years earlier. Very oddly, it was often on the same date, just years earlier. It was almost as if my interests were seasonal. Anyway, a few experiences like that taught me the value of documenting your work, if not for others, for your future self. Ten years later, it reads like someone else wrote it, but it sure is helpful compared to nothing.
  11. Wendy
    Mar 24, 2008
    20,772
    2,540
    Another way of looking at this is as a filter. A single integrator is a simple 1st order filter, two of them is a 2nd order filter. Add enough filtering anything becomes a sine wave.
    The diode shaper is something else, it is fundamentally a logarithmic amplifier.
  12. THE_RB
    Feb 11, 2008
    5,435
    1,305
    If your triangle wave has the top and bottom peaks clipped (with diodes or PSU limits etc) it requires even less filtering to get a "sine" output. :)
    To Elengr, I have built inverters that produced a decent sinewave out of the transformer, but they always needed waveforms very UN sine like driving the power components...
    It also depends a bit on the type and current of the load. Maybe you should say what the load is and why you need to make a sinewave inverter?
  13. Audioguru
    Dec 20, 2007
    9,411
    896
    An inverter is NEVER made from an amplified sine-wave because the amplifier is always linear and wastes a lot of power making lots of heat.
    Instead a sine-wave inverter uses Pulse-Width-Modulation at a high frequency where the output Mosfets switch completely on and off at a high frequency then the high frequency is simply filtered away with an LC filter.
    Since the Mosfets switch completely on and off then they do not waste much power and do not get hot.
    elengr likes this.
  14. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Actually they are. :) It's not common these days and it has never been a good idea with high power inverters, but there are linear sine wave inverters out there AG.
    The last one I made was for a small "antique" clock with a 60Hz AC mains synchronous motor.
  15. elengr
    Feb 5, 2011
    15
    I want to use sine wave inverter in UPS so that I can run my computer in case of power failure.
  16. kubeek
    Sep 20, 2005
    4,687
    805
    A computer will run fine with square wave or anything in-between, as the voltage is rectified and filtered to make a steady DC voltage for the SMPS. The electromagnetic noise will be higher with the square wave, but it shouldn´t affect the computer.
  17. Audioguru
    Dec 20, 2007
    9,411
    896
    AC motor speed controls don't work properly from a square-wave.
    Many electronic products also don't work properly from a square-wave because they rely on the 1.414 times higher peak voltage of a sine-wave.
  18. elengr
    Feb 5, 2011
    15
    Can you please upload a schematic of integrator circuit which at least converts square wave into triangular wave?
  19. Audioguru
    Dec 20, 2007
    9,411
    896
    An old 741, LM358 or LM324 opamp makes a triangle wave by integration when you have a frequency that exceeds its very low slew rate.
    I think an integrating opamp circuit makes a triangle wave when its input is a square wave.
  20. someonesdad
    Jul 7, 2009
    1,585
    141
    Just do a web search on "op amp integrator" and you'll get a zillion hits. Or look in "The Art of Electronics". Or here.
