Generating frequencies with transistors
Discussion in 'The Projects Forum' started by tom10122, May 16, 2014.
  1. tom10122
    May 16, 2014
    6
    How would I go about generating a frequency with a transistor?(Using a computer psu 12v rail) Can i Just use a small capacitance capacitor and when it charges up all the way have it discharge the transistor, using the small capacitor would mean it discharges fast enough to make a frequency?
  2. Experimentonomen
    Member
    Feb 16, 2011
    331
    46
    Try googling for oscillators.
  3. tom10122
    May 16, 2014
    6
    I thought about using one but I want to use 12v 3-4a for inductive coupling, and I couldn't find anything for higher currents.
  4. ronv
    Nov 12, 2008
    3,393
    1,449
    Why don't you spell out the objective. It will go a lot faster.:)
  5. MrChips
    Oct 2, 2009
    12,623
    3,451
    What frequency are you aiming for?
    A 555 timer circuit is easy to build.
  6. tom10122
    May 16, 2014
    6
    I want to be able to oscillate a coil with 12v about 3-4 amps (preferably) at a frequency (14 mhz if I did the math right), In order to wirelessly transmit electricity. I have Just about everything figured out except how to generate a frequency for the transmitting coil.
  7. tom10122
    May 16, 2014
    6
    14mhz, would a 555 work for higher amperages?
  8. MrChips
    Oct 2, 2009
    12,623
    3,451
    At 14mHz, yes, but not at 14MHz.
  9. tom10122
    May 16, 2014
    6
    Yeah sorry should've been more clear, 14 MHz .
  10. m4lyg0s
    Apr 17, 2014
    11
    just wao , you guys want him to use the timer as a control circuit (14MHz) and a power circuit for the 4A ??? using something like Opto-isolator/triacs ???? , idk if that will work , assuming it will work , you need that type of wave? (square wave)
  11. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,683
    1,295
    At that freq and current, it might be easier to drive the coil with a 14 MHz square wave and resonate the coil with a cap. Worked in color TVs since the 50's, although 4 A is a bit of a modification.
    ak
  12. wayneh
    Sep 9, 2010
    12,371
    3,224
    That's like saying you have everything for building a radio transmitter at 14MHz, except for the radio part. An RF amplifier at 14MHz and 4A is not a trivial part of your project.
  13. tom10122
    May 16, 2014
    6
    Thats how I'm resonating the receiving coil, I'll give it a shot thanks. Just thought it would be easier to build a circuit to transmit.
  14. THE_RB
    Feb 11, 2008
    5,435
    1,305
    How far are you expecting to "transmit the electricity"? And why the need for 14 MHz?
    Electric toothbrush chargers use two coils placed near each other and run at 50 Hz or 60 Hz. Transmits electricity just fine.
