Hi AAC forum.
I have a question about the practical details of using a basic op amp off a battery. For this application I don't think I could use a single rail supply op amp like the LM358N, because the output has to swing + and - about 0v as the offset.
I'm building a pretty simple 741 circuit, that needs a balanced supply of +9v 0v -9v and want to run it off a 9v battery, not a bench top supply.
If I had two 9v batteries I could make a balanced supply with that, but it would add a lot of bulk. To do it with one battery I guess the main option is a switching regulator used as an inverter to get the -ve rail. Can someone please recommend something cheap and easy to get that can do that? Surely this is quite a common task when using op amps.
Or for a basic circuit may be that's over the top and there is a simpler way to do it with a few discrete components?
The reason I thought about a switching regulator is at first I thought I might need to generate supplies of +15v 0 -15v from one 9v battery. I thought I could use one regulator to boost +9v to +15v and then another regulator to generate -15v from the boosted +15v. I was looking through data sheets to see if there is a device than can do boost and invert functions together in one IC.
Many thanks for any tips.
