generate signal from push button
Discussion in 'General Electronics Chat' started by collyd21, Nov 22, 2013.
  1. collyd21
    Jul 2, 2012
    14
    hi, is it possible for a signal to be generated from the motion of actually pressing a button in without any sort of voltage supplied to the button itself?
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Sure, use the button to push on a piezoelectric crystal, like one of these
  3. inwo
    Nov 7, 2013
    2,435
    315
    I believe so.
    Any details?
  4. BobTPH
    Jun 5, 2013
    808
    121
    Yes, focus a camera on the button and then use image processing to determine if it has been pushed.
    Bob
  5. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Finger pushes microswitch lever which pushes button and actuates switch.
  6. MrChips
    Oct 2, 2009
    12,656
    3,461
    Are you asking how to connect a push-button to your circuit?
    We generally use a pull-up resistor.
  7. wayneh
    Sep 9, 2010
    12,406
    3,256
    Maybe one of these.
  8. inwo
    Nov 7, 2013
    2,435
    315
    I was thinking on of these........................
  9. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    These are piezo powered traditionally. A large hammer is released on a piezo crystal via a spring mechanism, creates a high voltage pulse, and the spark will detonate the dynamite.
    Your local DIY store may not have them.
  10. gootee
    Apr 24, 2007
    447
    50
    You could also have the button push cause a small generator to rotate.
