generate pulse only on rising edge
Discussion in 'The Projects Forum' started by James Gordon, Jan 13, 2015.
  1. James Gordon
    Jan 13, 2015
    9
    I'm looking for some help: I need a digital circuit that will output a short pulse, wavelength unimportant, only upon receiving the rising edge of a pulse.
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,523
  3. James Gordon
    Jan 13, 2015
    9
    Hi Max,
    Thanks for the reply.
    Do you know of a solution that only utilises only basic gates and flip-flops please?
  4. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,523
    The 555 does it in a single 8 pin IC, is there a reason you want to make it a bit more complicated?
    Max.
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    Max has a good point.
    Otherwise maybe one XOR, one AND, one R & one C - in a particular topology.
  6. ronv
    Nov 12, 2008
    3,401
    1,464
    Do you mean digital only? No resistors or capacitors?
  7. James Gordon
    Jan 13, 2015
    9
    No capacitors or IC can be used, resistors acceptable. Thanks again for the continued effort :)
  8. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,523
    Is this some kind of masochistic challenge??:confused:
    Max.
  9. Bernard
    Aug 7, 2008
    4,240
    414
    Probably homework.
    #12 likes this.
  10. MrChips
    Oct 2, 2009
    12,636
    3,454
    One capacitor and one resistor.
  11. James Gordon
    Jan 13, 2015
    9
    It's to be implemented onto a CPLD/FPGA chip which only supports basic gates and flip flops.
  12. ronv
    Nov 12, 2008
    3,401
    1,464
    Since you have lots of gates, this should work.
  13. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,699
    1,298
    ronv's circuit is the classic approach. Be sure to tell the CPLD compiler not to reduce the inverter string. For Lattice software it is an option under net properties.
    ak
