Generate lowest cost two level circuit
Discussion in 'Homework Help' started by nyasha, Oct 7, 2009.
  1. nyasha
    Thread Starter Active Member
    Mar 23, 2009
    90
    Given the following function generate the lowest cost two level circuit using nand gates only
    f(x_{3},x_{2},x_{1},x_{0})=\sum(0,2,8,9,10,13)+D(1,3,6,7)
    My attempt to solution:
    I used Karnaugh's map to simplify to
    f=\bar x_{0}\bar x_{1}+x_{0}\bar x_{1}\bar x_{2}+x_{0}\bar x_{2}x_{3}+\bar x_{1}x_{2}\bar x_{3}
    \bar f=\bar{\bar x_{0}\bar x_{1}+x_{0}\bar x_{1}\bar x_{2}+x_{0}\bar x_{2}x_{3}+\bar x_{1}x_{2}\bar x_{3}}
    applied demorgan's theorem
    \bar f= x_{0}x_{1}\cdot\bar x_{0} x_{1} x_{2}\cdot\bar x_{0} x_{2}\bar x_{3}\cdot x_{1}\bar x_{2}x_{3}
    Guys l get stuck here.......i don't know if this is the lowest cost two level circuit ?
