Generate a Motorola S-Record file
Discussion in 'Embedded Systems and Microcontrollers' started by davidemasi, Nov 20, 2011.
  1. davidemasi
    Nov 20, 2011
    I am working on an ARM Cortex M3, with IDE Keil uV4.
    The Keil compiler generates only hex format file.
    I would need to generate a Motorola S-Record file.
    Is possible?
    How can I do?
    Davide
  2. ToBeFrank
    Nov 18, 2010
    13
    Keil includes fromelf.exe to convert the elf file to various formats. If you installed Keil in c:\keil, the path is c:\keil\ARM\BIN40\fromelf.exe. The --m32 option is for Motorola s19.
