general question- single line to ground fault
Discussion in 'General Electronics Chat' started by electric77, Mar 29, 2016.
  1. electric77
    Mar 18, 2016
    9
    so in general i have a system that consists of 5 buses, and at bus 2 i have a single line to ground fault.
    what are the effects of adding a generator to any of the 5 buses except bus 2? (here all currents increase in the lines except for that where the current fault occurs my question is why?)
    also what if i add an extra line from bus 2 to bus 4 where the fault occurs? (all all of my currents in all phases and buses drop why?)
  2. ErnieM
    Apr 24, 2011
    7,438
    1,626
    What is a bus? What are you generating? What did you drop?
    Perhaps some context would help explain what you mean.
    And welcome to the forums!
  3. wayneh
    Sep 9, 2010
    12,388
    3,245
    A system? I can't make heads or tails of your question without more detail than that.
    Scooped again by Ernie!
    ErnieM likes this.
  4. GopherT
    Nov 23, 2012
    6,315
    4,035
    Dude,
    Are you talking about a microcircuit on a printed circuit board or switch-gear in a factory?
  5. electric77
    Mar 18, 2016
    9
    so its a transmission system question:
    a bus=node
    in a transmission system we would transport power using a three-phase model (thus phase a, b, and c)
    now with that we could have faults where a line gets short circuited or ground etc
    my type of fault is single line to ground meaning phase a is grounded.
    i have simulated by circuit on a program called power world and iam looking at the results, but i was hoping to get some certification for why my currents would drop in all nodes except the fault node when i add an extra generator
    GopherT likes this.
  6. GopherT
    Nov 23, 2012
    6,315
    4,035
    I'm interested, Can you post the simulation results. Hopefully some type of graphic to show the standard case, (I imagine a standard 3-phase system (load may/may not be present). Then a fault-to-ground on "a", then you add additional generating power to one of the other two phases (and ground) (or across the other two phases) (or to all three phases?) - please clarify this fault and your additional generator.
    And I assume the additional generator is in-phase with the initial power.
