General PCB and circuit design considerations
Discussion in 'General Electronics Chat' started by Neosec, Feb 27, 2016.
  1. Neosec
    Feb 25, 2013
    36
    From time to time I see small breakout boards or single function boards with one or two IC chips on them. The ICs often don't require any external components for their operation and yet there are a few other components on the PCB.
    What are some typical or common components that are added to PCBs (circuits) to make them more robust or reliable? I know for example, decoupling (bypass) capacitors are placed near each IC, and diodes are used with solenoids to protect from inductive kick.
    What do you like to add to your circuit designs (PCBs) and why? Reverse polarity? ESD? Over voltage? RF Noise?
  2. ErnieM
    Apr 24, 2011
    7,447
    1,628
    This is entirely dependent on what is being built, why, and where it gets used.
    There are no simple answers. Sorry.
    MaxHeadRoom likes this.
  3. dl324
    Distinguished Member
    Mar 30, 2015
    3,397
    653
    It depends on your design objectives. You do everything required to make the circuit function, then you add features to make it more robust.
    If you need to worry about dumb users, you add circuitry to protect the circuit from them.
  4. Neosec
    Feb 25, 2013
    36
    I suppose I was thinking of an end user at the hobby level. Like arduino shields etc.
  5. AnalogKid
    Aug 1, 2013
    4,711
    1,303
    It isn't who, it's where. An Arduino running on my desk as a clock needs considerably less protection than the same part in a car flashing a string of LEDs in a sexy turn-signal pattern.
    ak
  6. dl324
    Mar 30, 2015
    3,397
    653
    Anyone using a bare PC board and connecting things to headers should know what they're doing, or be able to learn from mistakes.
  7. ErnieM
    Apr 24, 2011
    7,447
    1,628
    I would make sure it had proper on board bypass caps so my customers would be happy.
    Umm, no. First the expense of the parts
    Then there is the loss of opportunity profits. I want happy customers who blow up my nice shinny widget to come back and buy another.
