general knowledge
Discussion in 'Homework Help' started by amilton542, Jan 23, 2011.
  1. amilton542
    Thread Starter Active Member
    Nov 13, 2010
    494
    64
    why cant AC charge a DC battery? surely the positive peak has got to cause a chemical reaction of some sort. all i can think of is it will charge on the postive peak and discharge on the negative peak so the charge will cancel out, but if the supply remains postive there will be a constant charge, is this correct?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    You pretty much explained it yourself there.
  3. amilton542
    Nov 13, 2010
    494
    64
    thanks bill marsden, i came to the conclusion that a rectified AC source would charge a DC source
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    It would, but it could still damage the battery. Some batteries are sensitive to how they are charged.
    The Battery University
