General Electronic Questions
Discussion in 'General Electronics Chat' started by Keith W. Boyd, Jan 18, 2015.
  1. Keith W. Boyd
    Jan 18, 2015
    Hello, first time user here. I have a couple of questions I am just unable to find the answers to. I am sure there are smarter people than me on here that may be able to help me out. Thank you in advance if you can.
    1. About what is the operating frequency of a normally loaded switching power supply?
    2. In a TTL circuit, what is represented by 1.5V?
    Which instrument must always be used with the power off in a circuit under test, a voltmeter, ohmmeter, ammeter or frequency counter.
    Again, thank you if you can help
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    1. 100kHz to a couple of MHz.
    2. A voltage low enough to be a logic zero
    3. Ohmmeter, because it injects its own current into the circuit under test so that it can measure the resulting voltage, and thereby compute the resistance.
    GopherT likes this.
  3. GopherT
    Nov 23, 2012
    6,326
    4,054
    A perfect 3/3 even though the OP didn't bother numbering his third question.
  4. BillB3857
    Feb 28, 2009
    2,402
    348
    Fantastic answers for a set of homework questions!
  5. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    Hmmm.... I give it 2/3
    2) 1.5V is in the TTL gray zone. Logic 0 <= .8V, Logic 1 >=2.0V. 1.5V on a TTL input is usually interpreted as a Logic '1'.
    IIRC 1.5V is roughly what voltage an unconnected input measures at.
  6. GopherT
    Nov 23, 2012
    6,326
    4,054
    Some days, a kid need a day off.
  7. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    Agreed! The sad thing is that I can't remember what I had for lunch but I remember TTL specs from 40yrs ago.
