Hello everyone.
I have a GE timer model #15070. I am having problems hooking it up to my existing house wiring.
I removed an existing timer that had only 2 wires coming off it, and the new timer has 3 wires. The wires on the new switch are red (load), black(hot), and white (neutral).
The wiring in the house are all colored black. There are 2 black wires twisted together, and then there is another black wire.
I can hook up the black and red timer switch wires to the house wiring, and the on/off part of the switch works, but the timer does not. If I reverse the wires the same thing still happens. A friend told me to twist the black and red together and attach them to the twisted black wires, and attach the neutral to the single black wire. Nothing works when I do that. I reversed those as well, but still nothing happens.
Is it possible to hook this timer switch to my existing house wiring and actually have the timer also work?
Thanks in advance for any help you can give. It is very much appreciated!
