GE 1.5 HP motor part#5kcr48wn0292by
Discussion in 'The Projects Forum' started by ryanwxxx, Jun 15, 2009.
  1. ryanwxxx
    Jun 15, 2009
    Replacing old 3/4 hp 115v motor on boat lift with new 1.5 hp 115v wired to GE up/down switch.Switch has 4 wire to motor, white & green are down,black & red are up.Motor has 7 wires,white,orange & red are twisted together & black & yellow are together,brown & purple are by themselves.Would appreciate any help or a diagram on wiring this.
  2. hwy101
    May 23, 2009
    91
    28
  3. ryanwxxx
    Jun 15, 2009
    this manual didnt help,i have a different 1.5 hp motor,thanks alot though
  4. CDRIVE
    Jul 1, 2008
    2,223
    99
    If you have 7 conductors then chances are this is a dual (120V/240V) capacitor start motor. For 120V operation you will have 2 (120V) field windings (Stators) wired in parallel. To reverse this kind of motor you only need to swap the polarity of the Start winding. The Start winding exhibits a much higher DC resistance than the Run windings and it also has the start switch and start cap in series with it, so it's not hard to identify it.
