Gauss's law, cylinder
Discussion in 'Homework Help' started by ihatereg, Feb 13, 2010.
  1. ihatereg
    Mar 10, 2009
    9
    http://img404.imageshack.us/img404/4148/gauss3j.png (infinitly long)
    [latex]\Phi=\Phi_{0}(1-{r \over R}) {C \over m^2}[/latex]
    What's the charge of the cylinder of length L?
    I have done some calculations, but they were all wrong (checked by teacher).
  2. nubelube
    Jan 3, 2010
    16
    1. What problem are you try to solve (and what are your assumptions? e.g. charge density)? What do your symbols denote (e.g. what are C and m)?
    2. What did you do in your attempt to solve it? (and why, if it's not obvious)
  3. lmartinez
    Mar 8, 2009
    224
    6
    Are you attempting to find the electric field at a given distance due to a uniform line charge of an infinite length whose charge per unit length is given? ...
  4. ihatereg
    Mar 10, 2009
    9
    C over m are units. It should be m^3 actually.
    Anyway, question I gave you is additional one. The more important one is what is the electric field when r<R?
  5. ihatereg
    Mar 10, 2009
    9
  6. mik3
    Feb 4, 2008
    4,846
    63
    When r is less than R the electric field is zero.
  7. ihatereg
    Mar 10, 2009
    9
  8. mik3
    Feb 4, 2008
    4,846
    63
    You can assume an area inside the cylinder and calculate the net electric flux throught it.
  9. lmartinez
    Mar 8, 2009
    224
    6
