Gauss
Discussion in 'Physics' started by dearn, Oct 28, 2004.
  1. dearn
    Oct 25, 2004
    Can i get a simple explanation about Gauss Law and the application of it ??
    Thanx
    ^__^
  2. haditya
    Jan 19, 2004
    220
    Gauss law states that the product of electric flux and permitivity of the medium thru any surface is equal to the charge enclosed by the surface.
    ie mathematically
    (epsilon)E.ds=dq
    or (epsilon)d(phi)=dq
    (phi)=flux thru the surface
    in oredr to apply gauss law any"closed" suface(often referred to as gaussian surface) can be used... but we generally prefer to use surfaces that hav a certain symmetry in order to enable easy calcuation..
    if u can be more specific about the problem u are havin with the application of gauss theorem...i can probably help u out.
  3. vineethbs
    Nov 14, 2004
    56
    yes , that is right , but the law as stated by gauss uses the displacement vector because it is
    1 medium independant(normal incidence only)
    2 electric flux was historically defined in terms of the displacement vector only.
