Gathering place for threads pointing out errors in AAC book
Discussion in 'Feedback and Suggestions' started by Wendy, Jan 26, 2012.
Thread Status:
Not open for further replies.
  1. Wendy
    Thread Starter Moderator
    Mar 24, 2008
    20,772
    2,540
    This will cover all ground that has not been fixed. New errors should have their own threads, and if found valid will be referred to our editor.
    Error in capacitors section
    Many corrections in this thread, all grouped together.
    http://forum.allaboutcircuits.com/showthread.php?t=56406
    http://forum.allaboutcircuits.com/showthread.php?t=58837
    http://forum.allaboutcircuits.com/showthread.php?t=54447
    http://forum.allaboutcircuits.com/showthread.php?t=52531
    http://forum.allaboutcircuits.com/showthread.php?p=449029
    http://forum.allaboutcircuits.com/showthread.php?t=52362
    http://forum.allaboutcircuits.com/showthread.php?t=51894
    OK, I've made it back to this thread, which was addressed by Dennis. It is where I'm stopping. If anyone finds some I missed let me know in this thread.
    http://forum.allaboutcircuits.com/showthread.php?t=49803
    At this point I email Dennis. And the cycle continues at a later date.
  2. exscape
    Jan 19, 2012
    28
    I found two more errors in the inductors section, and posted them to this thread (which is already in the list above, so I'm not sure whether I need to post that it's updated now).
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Nope, no misunderstanding. The idea is when Dennis comes by and enters the corrections I will unsticky this thread, and start a new one.
    I may move your corrections to the original thread. Feel free to edit my post to add new corrections, having everything in one place should make it easier.
  5. Dcrunkilton
    E-book Co-ordinator
    Jul 31, 2004
    416
    11
    Error in t=56406 thread have been entered at ibiblio.
    Files and images changed:
    Volume 5 Ref colors.sml contrib.sml
    Volume 2 AC resonant.sml contrib.sml edit
    The errors in "Error in capacitor section" are related to
    Details follow:
    Apparently I violated Tony's image numbering convention:
    http://www.allaboutcircuits.com/l_graphic.html
    For images in the Reference Volume 5 , I was Using Volume 1 numbers which were already in use. This works in html at ibiblio or the PDF because the images are in separate subdirectories, where as AAC puts them all in one subdirectory.
    The fix was for me to convert some images I had added to volume 5 to comply with Tony's numbering convention. (Tony does re-use some images. For example, a few in Vol 5 Ref have been copied from Vol 1 DC. This works if the images in both subdirectories are identical.)
    Volume 5 equations.sml contrib.sml changed. Images that need to be reloaded from ibiblio to AAc include:
    Volume 5, Ref: 1109[5-9].png 1110[02].png
    Volume 2, DC: 1023[12389].png 10241.png
    It may be better to re-load all images, as they get corrections from time to time.
    I will post back to this thread as I enter changes
    Georacer likes this.
  6. Dcrunkilton
    E-book Co-ordinator
    Jul 31, 2004
    416
    11
    There are some links that we can fix -- on the same AAC page. And there are links to other pages which we cannot fix at this time. No change at this time.
    Changes entered.at ibiblio
    Bill_Marsden's proposed changes entered at ibiblio.org.
    Thank you all for your input.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    Thanks Dennis. I will contact you later about some of the other stuff I'm trying to figure out, but this thread is finished. I will close it, and eventually start a new one in the near future.
Thread Status:
